BlockStyler rename block
How to rename the block name such as after added button that named "button0" but I want to change to another name?
Terry
Re: BlockStyler rename block
Go to the Dialog construction window and select the Button block, then look in the lower section named Properties and find in there the General section. Double click the BlockID and you can type in a new name:
Dell 7530 Precision, Win10, 32GB. Developing in: Java | C | KF
Production: [NX12.0.2 MP1]
THANK YOU
