Bounding Box Journal - Error
I had this journal from one of the discussion here and now I am getting this error when play.
Can someone please help me to solve this issue?
Journal file attached
Re: Bounding Box Journal - Error
The journal that you posted seems to work fine for me; except for the conversion of the volume from cubic inches to cubic centimeters, but that isn't the problem you asked about.
I would suggest changing line 95 to read:
If MyForm.ShowDialog = System.Windows.Forms.DialogResult.OK Then
but I'm not 100% sure that will take care of the issue you are having.
What version of NX are you using and what versions of the .net framework do you have installed?
That works!
Thanks!!
