Bounding box in Python
Hi there, I'm trying to create a bounding box for solid bodies in Python.
I'm sure there is a straightforward to do it in C++  but I prefer to work in python. Below is the documentation link and my code
https://docs.plm.automation.siemens.com/data_services/resources/nx/10/nx_api/en_US/custom/nxopen_pyt...
def boundingbox():
# Get Session
NXSession = NXOpen.Session.GetSession()
# Get Work Part
workPart = NXSession.Parts.Work
# Get Displayed Part
displayPart = NXSession.Parts.Display
nullFeature = NXOpen.Features.Feature.Null
#origin = Point3d(0.0, 0.0, 0.0)
def processPart(partObject):
for bodyObject in partObject.Bodies:
processBodyFaces(bodyObject)
processBodyEdges(bodyObject)
##access all parts in an nx session
for partObject in NXSession.Parts:
global my_part
my_part=processPart(partObject)
my_part.AskBoundingBox()
Re: Bounding box in Python
You need to get the UF session, then access ModlGeneral.AskBoundingBoxExact() from there.
This is just "best-guess" code - I haven't tried making yours work so that I could add the reply in:
import NXOpen.UF
def boundingbox():
    # Get Session
    theUfSession = NXOpen.UF.UFSession.GetUFSession()
    # Get Work Part
        global my_part
    (min_corner,directions,distances) = theUfSession.ModlGeneral.AskBoundingBoxExact(my_part.Tag, NULL_TAG)
Thanks for the reply. I've imported the Uf library and now I am trying various syntax.
def boundingbox():
# Get Session
# Get UF session
# Get Work Part
#workpart = NXOpen.session.Parts.Work
#nullFeature = NXOpen.Features.Feature.Null
##access all solid bodies in a part
#def processPart(partObject):
# for bodyObject in partObject.Bodies:
# processBodyFaces(bodyObject)
# processBodyEdges(bodyObject)
global my_part
boundedbox=NXOpen.UF.ModlGeneral
boundedbox.AskBoundingBox(displayPart)
I showed the correct syntax of the call in my original reply. Here is fully working code that will list the bounding box for each body with respect to the WCS:
import NXOpen
import NXOpen.UF
theSession = NXOpen.Session.GetSession()
theLw = theSession.ListingWindow
theUI = NXOpen.UI.GetUI()
def main(*args):
    workPart = theSession.Parts.BaseWork
    bodies = workPart.Bodies
    for body in bodies:
        (min_corner, directions, distances) = theUfSession.ModlGeneral.AskBoundingBoxExact(body.Tag, 0)
        theLw.Open()
        theLw.WriteLine("Bounding box for " + body.JournalIdentifier)
        theLw.WriteLine("  Min Corner: ")
        theLw.WriteLine("    X: " + str(min_corner[0]))
        theLw.WriteLine("    Y: " + str(min_corner[1]))
        theLw.WriteLine("    Z: " + str(min_corner[2]))
        theLw.WriteLine("  Direction Vectors: ")
        theLw.WriteLine("    X: (" + str(directions[0][0]) + ", " + str(directions[0][1]) + ", " + str(directions[0][2]) + ")")
        theLw.WriteLine("    Y: (" + str(directions[1][0]) + ", " + str(directions[1][1]) + ", " + str(directions[1][2]) + ")")
        theLw.WriteLine("    Z: (" + str(directions[2][0]) + ", " + str(directions[2][1]) + ", " + str(directions[2][2]) + ")")
        theLw.WriteLine("  Distances: ")
        theLw.WriteLine("    X: " + str(distances[0]))
        theLw.WriteLine("    Y: " + str(distances[1]))
        theLw.WriteLine("    Z: " + str(distances[2]))
        theLw.WriteLine("")
# Main program.
if __name__ == "__main__":
    main()
Thanks, that worked. is there a way to draw a bounding box with Feature Builder?
Esteemed Contributor
Do you need the bounding box as temporary display or as solid?
Feature builder can't do it.
You would use temporary lines or a block.
Honored Contributor
Honored Contributor
Depends on the version of NX in use. NX 10 has added the "create box" command to the modeling application which will create an associative bounding box around the selected geometry.
I'd suggest recording a journal while using the "create box" command to see what code gets recorded.
Thanks, the create box command did the trick
## create bounding box
toolingBoxBuilder1 = workPart.Features.ToolingFeatureCollection.CreateToolingBoxBuilder(NXOpen.Features.ToolingBox.Null)
#create instance of a class
matrix1 = NXOpen.Matrix3x3()
#attributes
matrix1.Xx = 1.0
matrix1.Xy = 0.0
matrix1.Xz = 0.0
matrix1.Yx = 0.0
matrix1.Yy = 1.0
matrix1.Yz = 0.0
matrix1.Zx = 0.0
matrix1.Zy = 0.0
matrix1.Zz = 1.0
global xorigin, yorigin, zorigin
xorigin=min_corner[0]+(distances[0]/2)
yorigin=min_corner[1]+(distances[1]/2)
zorigin=min_corner[2]+(distances[2]/2)
#assigning a method to variable
position1 = NXOpen.Point3d(xorigin, yorigin, zorigin)
toolingBoxBuilder1.SetBoxMatrixAndPosition(matrix1, position1)
toolingBoxBuilder1.CalculateBoxSize()
toolingBoxBuilder1.XValue.RightHandSide = str(distances[0])
toolingBoxBuilder1.YValue.RightHandSide = str(distances[1])
toolingBoxBuilder1.ZValue.RightHandSide = str(distances[2])
nXObject1 = toolingBoxBuilder1.Commit()
toolingBoxBuilder1.Destroy()
The CreateToolingBoxBuilder is usually licensed with one of the tooling wizard licenses, like Mold Wizard, Electrode Design, etc.
I don't know, if this is now included in the modeling license starting with NX 10.
Just to make others aware of the problem, that it might not work in all circumstances.
Honored Contributor
Honored Contributor
