cancel
Bundle NX12451(CAD/CAM nodelock) Add-on NX30408(Turning) and NX30409(5X)
Hi All
For new bundle NX12451(CAD/CAM nodelock). Can add-on NX30408(Turning) and NX30409(5X)?
Thank you.
Re: Bundle NX12451(CAD/CAM nodelock) Add-on NX30408(Turning) and NX30409(5X)
NX12451 is not listed as a pre-requisite for either of those add-ons, but from a technical standpoint it will work.
Anthony Galante - Senior Support Engineer - PhoenxPLM (Australia & New Zealand Siemens Solutions Partner)
http://www.phoenxplm.com.au/email/2014_signature/signature_videoCenter.jpg
Hi Anthony
Thank you for your suggestion.
But I test in P2O (load order) system. It can't add-on to NX12451.
How to solve this problem?
There should be no problem with the add-ons.
This seems to be an internal issue, so please contact your channel support person in Siemens.
Mark Rief
Retired Siemens
