Do you mean
Reply
Solved! Go to solution
Bundle Segment in NXOPen
[ Edited ]
I used to develop application in CAA CATIA.
Please what's the equivalent to CATIA BundleSegment in NX Open.
Thanks in Advance,
Re: Bundle Segment in NXOPen
Can you describe what bundle segment was in Catia?
Mark Rief
Retired Siemens
A bundle segment is a subdivision of geometrical bundle. Bundle segment route may be defined by electrical flexible curve ( computed under geometrical and physical constraints ). Managed by CATIEhiBundleSegment interface. Please see attached picture( It's a CATIA picture).
Solution
Solution
Accepted by topic author RM1
‎12-16-2016 03:37 AM
Bundle has no equivalent meaning. NX has routing path segments (centerline curves or lines), and stock. Stock can be mechanical stock like pipes and tubes, or electrical bundle stock which represents any number of wires and cables in a harness gathered together.
Doug Peters our Siemens contact partner!
