Button SENSITIVITY dynamically in MenuScript
How to make SENSITIVITY ON/OFF for a custom button during application mode change(Modelling,Drating) dynamically in MenuScript?
for an example SENSITIVITY ON during Modelling mode and SENSITIVITY OFF during Drafting mode
Re: Button SENSITIVITY dynamically in MenuScript
You will have to add a separate menu file to the application button using the MENU/APPEND keyword.
This menu file is to be located in the application folder contained in a folder pointed to by custom_dirs.dat or UGII_[SITE|GROUP|USER]_DIR.
Hi stefen Pendal,
I have prodcued the same way you have said.but i could not get  resutls.
Please provide me a sample menuscript code.
Best Regards,
Sasikumar
You usually don't change the tool bar button, but HIDE the menu entry or only add it to the application it is used in.
There has been a similar question a few days ago, have you read that?
In NX9 there is a new structure for ribbon and toolbar files, that uses profile folders to add and remove them based on the application. Perhaps this also works with .men files?
Mark Rief
Retired Siemens
