C++ , UfSession ?
I'm trying to write a program using C++ and NXOpen. First programming with C++...
One of the function must extract the related nodes of each element of the model (the objective is to evaluate the center of each element).
With VB.net I would have used something like that :
theUFSession.Sf.LocateAllMeshes(meshtag, num_of_mesh, mesh_tags_p)
theUFSession.Sf.LocateElement(mesh_tags_p(i), num_of_elems_mesh, element_tags_p)
mon_elem = NXOpen.Utilities.NXObjectManager.Get(element_tags_p(j))
Elem_Nodes = mon_elem.GetNodes
But I can't find the equivalent in C++
Does someone could help me ? To find the equivalent, or someother method ?
Many Thanks !
Marie
Re: C++ , UfSession ?
This is the Open C API. This API is wrapped for .NET, Python and Java. You use it directly with C++
Open C API
See also the interoperability sample provided with the NX installation:
UGOPEN\SampleNXOpenApplications\C++\InteropNXOpenWithUFunc\InteropNXOpenWithUFunc.cpp
Thank you Jim !
that's what I was looking for without any success ;-)
Have to add : #include <uf_sf.h> in my case.
Have a nice week end !
Marie
Hello @Beetle ,
thanks for yout post, I will also have a look at this !
Have a nice week end,
Marie
