CAM Journal Execution Error
 I get the following error when I try to run a journal from inside NX. When I run it from a .bat file it runs fine. Any explaination?
Ron
NX10.0.3.5
Windows 7
Re: CAM Journal Execution Error
Are you sure that you use the same CAM configuration in both NX sessions?
It seems that you use a different CAM configuration and the post-processor specified in the journal is not found.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0 | TcVis 11.4
I agree with @Stefan_Pendl - check the configurations.
Compare the 2 syslog files, and check the value of UGII_CAM_CONFIG.
Mark Rief
Retired Siemens
Thanks for the help. That was the issue.
