CAM : cutting parameters vb
hello ,
I created a code that changes the cutting parameters on selected operations, for this I used the example SampleNXOpenApplications / OntSelectionBoilerPlate.vb in the NX file
I select the operations, and I have a dialog box that appears, asking me to put an thickness, for now everything works, for I have to go against my value every time, there is a possibility that this dialog box appears only once for all selected operations ?, and that my value applies for all operations
I am beginner in programming vb
Thank you for your help
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Re: CAM : cutting parameters vb
To only enter the value once, make sure to ask for it outside of the loop that cycles through the operations.
Would be good to post your code, so we can see what you really have and don't rely on guessing Smiley Wink
 it's true !! Smiley Embarassed
    Function CutParameters(ByVal operationBuilder As CAM.OperationBuilder) As Boolean
        'What type of a builder is this?
        If TypeOf operationBuilder Is CAM.MillOperationBuilder Then
            Dim millOperationBuilder As CAM.MillOperationBuilder = operationBuilder
            'From the Operation Builder get the Cutting Parameters Object
            Dim cutParams As CAM.MillCutParameters = millOperationBuilder.CutParameters
			REM Dim CurrentName = new  camObject.Name()
		    REM Dim CurrentName As String = camObject.Name()
            ' Now we are ready to change the parameters of cutting
				cutParams.PartStock.Value = (NXInputBox.GetInputString("Surépaisseur de Coupe:","Valeur","0"))
            Return True
        End If
        Return False
    End Function
www.adgroupe.com
Dim thePartStock As Double = NXInputBox.GetInputNumber("Surépaisseur de Coupe:","Valeur",0.0)
CutParameters(theOperationBuilder, thePartStock)
Function CutParameters(ByVal operationBuilder As CAM.OperationBuilder, ByVal PartStockValue As Double) As Boolean
        cutParams.PartStock.Value = PartStockValue
        Return True
    End If
    Return False
End Function
Something along these lines Smiley Wink
Yes Smiley Tongue
thanks
www.adgroupe.com
