Calling SAP PLM API from Knowledge Fusion
Hi Friends
I am having requirement to integrate KF appliocation with SAP PLM, Is there is any way we can call SAP PLM API from Knowledge Fusion.
Thanks in advance
Nij
Re: Calling SAP PLM API from Knowledge Fusion
In general, you can call C-callable functions from KF. So, assuming the SAP API functions are C-callable, you could get this to work, in principle. But the KF-to-C interface essentially requires you to do all the "marshalling" of passed parameters yourself, so it's quite tedious, and it gets difficult if the parameters are complex data structures.
山田
yamada
Thank you very much Yamada
Nij
