Can you run ITK code in a journal?
Hello, I am looking for a possible solution that involves using ITK. Does this code need to be compiled or can I run it in a journal?
Re: Can you run ITK code in a journal?
ITK code needs to be compiled and linked, and then the .DLL needs to be registered with Teamcenter.  It cannot be run as interpreted source, like an NXOpen journal.
