Cannot select Points on Solid Silhouette Curve
Hello all, i am using a BlockStyler's 'select Object' block to select points on a drafting view, the block works fine till i try to select a point on Solid Silhouette Curve as the mouse cursor appears as it's processing something then nothing is selected. i any one has a solution for this problem i will be very grateful. thanks in advance
