Chained Curves
Innovator
Innovator
Given a single curve...and there are other curves connected to it.
How do I get all curves that are connected to it?
Re: Chained Curves
Do you want all curves that are connected a given curves or do you want to retrieve like a chain of connected curves, the given curve is part of?
You could compare the start and end points of your curves to check if they are connected.
Check this out:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&dt=nx-api&q=sample+prog...
Or you create a section based on the given curve. Creating the section you can specify a chain rule and if needed that you are only looking for curves that are connected tangent.
In this exmaple, a section is created:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&file_type=text&q=UF_MOD...
Re: Chained Curves
