cancel
Change Source JT File Properties
Hey guys,
me again :-P I recently worked with an assembly that contained JTs. It took me a while to figure out how to copy / clone the whole assembly including the JTs but now it works...
Back to topic:
If I open the cloned JT (which actually is a part file) right click on it and open the properties panel there is a tab called "JT File" which lists a Source JT file, a JT File Last Changed date anda  Last Updated from JT date (picture below).
My question is:
Can I edit the source jt file path (marked in red)  programmatically so that it points to a new location ?
NX Version: 10.0.1.4
Programming Language: JAVA / C++
Thanks in advance! Smiley Happy
