Change characteristic of all PMI FCF in part
I'm trying to edit all PMI FCF in parts and change its characteristic from Straingtness to Flatness. What I've come up with is:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        For Each myFCF As Annotations.Fcf In workPart.Fcfs
            'lw.WriteLine(myFCF)
            pmiFeatureControlFrameBuilder.Characteristic = NXOpen.Annotations.FeatureControlFrameBuilder.FcfCharacteristic.Flatness
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
I'm unable to select PMI FCF and edit it. Please help me.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
4 REPLIES 4
Re: Change characteristic of all PMI FCF in part
Please give any clue on how to select single PMI FCF in part so that I can manage to edit it further.
Samadhan
Below is the code which does what I want:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
        Dim myFCF
        For Each myFCF In workPart.Annotations.fcfs.ToArray() ' Change fcfs to another annotation name to loop thru all of them in part
             Dim x as string
             x = myFCF.JournalIdentifier
        Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
        Dim fcf1 As NXOpen.Annotations.Fcf = CType(workPart.FindObject(x), NXOpen.Annotations.Fcf)
        Dim pmiFeatureControlFrameBuilder1 As NXOpen.Annotations.PmiFeatureControlFrameBuilder = Nothing
        pmiFeatureControlFrameBuilder1 = workPart.Annotations.CreatePmiFeatureControlFrameBuilder(fcf1)
        ''' Change characteristics
        pmiFeatureControlFrameBuilder1.Characteristic = NXOpen.Annotations.FeatureControlFrameBuilder.FcfCharacteristic.Flatness
        Dim nXObject1 As NXOpen.NXObject = Nothing ''' Commit changes
        nXObject1 = pmiFeatureControlFrameBuilder1.Commit()
        Next
        lw.Close()
    End Sub
    End Function
End Module
Samadhan
2 items of note:
  1. Don't forget to destroy the builder object when you are done with it. The objects may show some strange behavior later if you edit it and forget to destroy the builder object that performed the edits.
  2. There's no need to get the journal identifier of the object in this case. If you declare the loop variable with the proper type, you can use it directly.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
        For Each myFCF as NXOpen.Annotations.Fcf In workPart.Annotations.fcfs
            pmiFeatureControlFrameBuilder1 = workPart.Annotations.CreatePmiFeatureControlFrameBuilder(myFCF)
            pmiFeatureControlFrameBuilder1.Destroy
        Next
        lw.Close()
    End Sub
    End Function
End Module
Thank you for improving the answer!
Samadhan
