Changing part handles
Hello everyone!
I am currently working on a journal that uses a block UI styler to analyse an assembly. The result of this analysis is an excel sheet that contains the different parts and some faces that are of interest. I know that I cannot work with Tags as they change from session to session. So I thought I could save the handles.
Now I am getting a bit confused: When I run my analysis twice, I can see that the part handles change in every session. The face handles stay the same. My current procedure is to get the protoype and the handle of the tag during my analysis.
I hope you can help me with my issue, thank you in advance!
Re: Changing part handles
Hi @SteveU
Yes, You are right, Sometimes that happens(because of Instance and Occ), Once you get the handle. Decompose it by UF_TAG_decompose_handle API. Check the documentation.
伊尔凡
