Checking a set of curves for extrusion
Innovator
Innovator
Is there a way to check if a given set of curves will make a valid extrusion...aka.. a solid body?
Re: Checking a set of curves for extrusion
Do the extrusion for each curve and check if it fails (using a try and catch if you are using C++). Then undo your operation if you dont want to keep the extrusion
Elias.
There is an example in 'Solution Center' search for 'validate chainability of selected curves'.
Suresh
