Checking for the availability of a specific license
Hello everyone!
Is it possible to use NX Open to check whether the specific license (advanced assemblies is my case) is available?
Re: Checking for the availability of a specific license
Esteemed Contributor
theSession.LicenseManager.Reserve("solid_modeling", Nothing)
If this call fails, then there is no solid modeling license available nor a bundle used that includes it.
Thanks! Good to know. Does this code actually reserves the license, if successful?
Yes, the namespace also includes a method to explicitly free the license, but usually this is done automatically by NX from what I have seen.
So what I basically do here is reserve the license and if successful, just release it?
Also, how do you define "Nothing" in this case? I'm afraid I do not understand the contexts yet.
Update: Oops, just realised Nothing is null in VB. Smiley Happy
From the description of the method it is not clear what a context will be, so specifying nothing will check the license in the default context, which has always worked in my cases.
In addition I don't really release the license, since I do the check to allow the user to enter the modeling application for example, so the license is released automatically after the modeling application has been exited.
I would release the license only when the utility doesn't need it anymore.
Here is the link to the NXOpen Programmer's Guide documentation, where User-Defined Contexts are explained.
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_api/#uid:xid1162445:index_nxopen_prog_guide:id...
Also look at the Remarks section of the LicenseManager Class, in the NXOpen .Net Api Reference, there is also some interesting information there.
