Cloning Assembly
Innovator
Innovator
Does anybody know how to properly clone an assembly using NXOpen.UF.UFClone?
Any information would be greatly appreciated.
Re: Cloning Assembly
Try searching the GTAC solution center for UFClone code.
Also, the following thread has some code in it that might be of use:
http://community.plm.automation.siemens.com/t5/NX-Languages/How-to-avoid-output-on-Information-Windo...
