Combination of Journaling and Block Styler
Hi everyone,
I managed to create a code, which create a linked Body of a selected solid body. But I want to use my own selection mask. With the help of the UI Block Styler I created a funktional mask, but I can not combine both codes. I hope someone of you will find the mistake I am making.
I am working with NX10, and thats my code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.BlockStyler
Imports NXOpen.UF
'Represents Block Styler application class
Public Class BlockStyler160704_Auswahl_Kathodenplatte
'class members
Private Shared theSession As Session
Private Shared theUI As UI
Private theDlxFileName As String
Private theDialog As NXOpen.BlockStyler.BlockDialog
Private group0 As NXOpen.BlockStyler.Group ' Block type: Group
Private drawingArea0 As NXOpen.BlockStyler.DrawingArea ' Block type: Drawing Area
Private selection0 As NXOpen.BlockStyler.SelectObject ' Block type: Selection
'Bit Option for Property: SnapPointTypesEnabled
Public Shared ReadOnly SnapPointTypesEnabled_UserDefined As Integer = 1
Public Shared ReadOnly SnapPointTypesEnabled_Inferred As Integer = 2
Public Shared ReadOnly SnapPointTypesEnabled_ScreenPosition As Integer = 4
Public Shared ReadOnly SnapPointTypesEnabled_EndPoint As Integer = 8
Public Shared ReadOnly SnapPointTypesEnabled_MidPoint As Integer = 16
Public Shared ReadOnly SnapPointTypesEnabled_ControlPoint As Integer = 32
Public Shared ReadOnly SnapPointTypesEnabled_Intersection As Integer = 64
Public Shared ReadOnly SnapPointTypesEnabled_ArcCenter As Integer = 128
Public Shared ReadOnly SnapPointTypesEnabled_QuadrantPoint As Integer = 256
Public Shared ReadOnly SnapPointTypesEnabled_ExistingPoint As Integer = 512
Public Shared ReadOnly SnapPointTypesEnabled_PointonCurve As Integer = 1024
Public Shared ReadOnly SnapPointTypesEnabled_PointonSurface As Integer = 2048
Public Shared ReadOnly SnapPointTypesEnabled_PointConstructor As Integer = 4096
Public Shared ReadOnly SnapPointTypesEnabled_TwocurveIntersection As Integer = 8192
Public Shared ReadOnly SnapPointTypesEnabled_TangentPoint As Integer = 16384
Public Shared ReadOnly SnapPointTypesEnabled_Poles As Integer = 32768
Public Shared ReadOnly SnapPointTypesEnabled_BoundedGridPoint As Integer = 65536
Public Shared ReadOnly SnapPointTypesEnabled_FacetVertexPoint As Integer = 131072
'Bit Option for Property: SnapPointTypesOnByDefault
Public Shared ReadOnly SnapPointTypesOnByDefault_EndPoint As Integer = 8
Public Shared ReadOnly SnapPointTypesOnByDefault_MidPoint As Integer = 16
Public Shared ReadOnly SnapPointTypesOnByDefault_ControlPoint As Integer = 32
Public Shared ReadOnly SnapPointTypesOnByDefault_Intersection As Integer = 64
Public Shared ReadOnly SnapPointTypesOnByDefault_ArcCenter As Integer = 128
Public Shared ReadOnly SnapPointTypesOnByDefault_QuadrantPoint As Integer = 256
Public Shared ReadOnly SnapPointTypesOnByDefault_ExistingPoint As Integer = 512
Public Shared ReadOnly SnapPointTypesOnByDefault_PointonCurve As Integer = 1024
Public Shared ReadOnly SnapPointTypesOnByDefault_PointonSurface As Integer = 2048
Public Shared ReadOnly SnapPointTypesOnByDefault_PointConstructor As Integer = 4096
Public Shared ReadOnly SnapPointTypesOnByDefault_BoundedGridPoint As Integer = 65536
#Region "Block Styler Dialog Designer generator code"
'Constructor for NX Styler class
Public Sub New()
Try
theSession = Session.GetSession()
theUI = UI.GetUI()
theDlxFileName = "160704_Auswahl_Kathodenplatte.dlx"
theDialog = theUI.CreateDialog(theDlxFileName)
theDialog.AddApplyHandler(AddressOf apply_cb)
theDialog.AddOkHandler(AddressOf ok_cb)
theDialog.AddUpdateHandler(AddressOf update_cb)
theDialog.AddInitializeHandler(AddressOf initialize_cb)
theDialog.AddDialogShownHandler(AddressOf dialogShown_cb)
Catch ex As Exception
'---- Enter your exception handling code here -----
Throw ex
End Try
End Sub
#End Region
Public Shared Sub Main()
Dim theBlockStyler160704_Auswahl_Kathodenplatte As BlockStyler160704_Auswahl_Kathodenplatte = Nothing
Try
theBlockStyler160704_Auswahl_Kathodenplatte = New BlockStyler160704_Auswahl_Kathodenplatte()
' The following method shows the dialog immediately
theBlockStyler160704_Auswahl_Kathodenplatte.Show()
theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
Finally
If theBlockStyler160704_Auswahl_Kathodenplatte IsNot Nothing Then
theBlockStyler160704_Auswahl_Kathodenplatte.Dispose()
theBlockStyler160704_Auswahl_Kathodenplatte = Nothing
End If
End Try
End Sub
Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
Return CType(Session.LibraryUnloadOption.Immediately, Integer)
' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
End Function
' Following method cleanup any housekeeping chores that may be needed.
' This method is automatically called by NX.
Public Shared Sub UnloadLibrary(ByVal arg As String)
Try
End Try
End Sub
'This method shows the dialog on the screen
Public Sub Show()
Try
theDialog.Show
End Try
End Sub
'Method Name: Dispose
Public Sub Dispose()
If theDialog IsNot Nothing Then
theDialog.Dispose()
theDialog = Nothing
End If
End Sub
'---------------------Block UI Styler Callback Functions------------
'Callback Name: initialize_cb
Public Sub initialize_cb()
Try
group0 = CType(theDialog.TopBlock.FindBlock("group0"), NXOpen.BlockStyler.Group)
drawingArea0 = CType(theDialog.TopBlock.FindBlock("drawingArea0"), NXOpen.BlockStyler.DrawingArea)
selection0 = CType(theDialog.TopBlock.FindBlock("selection0"), NXOpen.BlockStyler.SelectObject)
End Try
End Sub
'Callback Name: dialogShown_cb
'This callback is executed just before the dialog launch. Thus any value set
'here will take precedence and dialog will be launched showing that value.
Public Sub dialogShown_cb()
Try
'---- Enter your callback code here -----
End Try
End Sub
'Callback Name: apply_cb
Public Function apply_cb() As Integer
Dim errorCode As Integer = 0
Try
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim nullFeatures_Feature As Features.Feature = Nothing
Dim waveLinkBuilder1 As Features.WaveLinkBuilder
waveLinkBuilder1 = workPart.BaseFeatures.CreateWaveLinkBuilder(nullFeatures_Feature)
Dim waveDatumBuilder1 As Features.WaveDatumBuilder
waveDatumBuilder1 = waveLinkBuilder1.WaveDatumBuilder
Dim compositeCurveBuilder1 As Features.CompositeCurveBuilder
compositeCurveBuilder1 = waveLinkBuilder1.CompositeCurveBuilder
Dim waveSketchBuilder1 As Features.WaveSketchBuilder
waveSketchBuilder1 = waveLinkBuilder1.WaveSketchBuilder
Dim waveRoutingBuilder1 As Features.WaveRoutingBuilder
waveRoutingBuilder1 = waveLinkBuilder1.WaveRoutingBuilder
Dim wavePointBuilder1 As Features.WavePointBuilder
wavePointBuilder1 = waveLinkBuilder1.WavePointBuilder
Dim extractFaceBuilder1 As Features.ExtractFaceBuilder
extractFaceBuilder1 = waveLinkBuilder1.ExtractFaceBuilder
Dim mirrorBodyBuilder1 As Features.MirrorBodyBuilder
mirrorBodyBuilder1 = waveLinkBuilder1.MirrorBodyBuilder
extractFaceBuilder1.FaceOption = Features.ExtractFaceBuilder.FaceOptionType.FaceChain
waveLinkBuilder1.Type = Features.WaveLinkBuilder.Types.BodyLink
extractFaceBuilder1.AngleTolerance = 45.0
waveDatumBuilder1.DisplayScale = 2.0
waveLinkBuilder1.CopyThreads = False
extractFaceBuilder1.ParentPart = Features.ExtractFaceBuilder.ParentPartType.OtherPart
mirrorBodyBuilder1.ParentPartType = Features.MirrorBodyBuilder.ParentPart.OtherPart
theSession.SetUndoMarkName(markId1, "WAVE Geometry Linker Dialog")
compositeCurveBuilder1.Section.DistanceTolerance = 0.01
compositeCurveBuilder1.Section.ChainingTolerance = 0.0095
extractFaceBuilder1.Associative = True
extractFaceBuilder1.MakePositionIndependent = False
extractFaceBuilder1.FixAtCurrentTimestamp = False
extractFaceBuilder1.HideOriginal = False
extractFaceBuilder1.InheritDisplayProperties = False
Dim selectObjectList1 As SelectObjectList
selectObjectList1 = extractFaceBuilder1.BodyToExtract
extractFaceBuilder1.CopyThreads = False
Dim body1 As Object = Nothing
Dim added1 As Boolean = False
body1 = selection0
added1 = selectObjectList1.Add(body1)
Dim nXObject1 As NXObject
nXObject1 = waveLinkBuilder1.Commit()
theSession.SetUndoMarkName(markId1, "WAVE Geometry Linker")
waveLinkBuilder1.Destroy()
Dim markId5 As Session.UndoMarkId
markId5 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Assign Name")
Dim extractFace1 As Features.ExtractFace = CType(nXObject1, Features.ExtractFace)
extractFace1.SetName("Kathodenplatte")
theSession.SetUndoMarkVisibility(markId5, "Assign Name", Session.MarkVisibility.Visible)
errorCode = 1
End Try
apply_cb = errorCode
End Function
'Callback Name: update_cb
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
Try
If block Is drawingArea0 Then
'---- Enter your code here -----
ElseIf block Is selection0 Then
End If
End Try
update_cb = 0
End Function
'Callback Name: ok_cb
Public Function ok_cb() As Integer
Try
errorCode = apply_cb()
errorCode = 1
End Try
ok_cb = errorCode
End Function
'Function Name: GetBlockProperties
'Returns the propertylist of the specified BlockID
Public Function GetBlockProperties(ByVal blockID As String) As PropertyList
GetBlockProperties = Nothing
Try
GetBlockProperties = theDialog.GetBlockProperties(blockID)
End Try
End Function
End Class
Re: Combination of Journaling and Block Styler
Hi Boebel!
So you managed some code (e.g. a journal) to create a linked body. Then you used the Block Styler to create a GUI (so the user can do some selections) and what you tried is to copy your code in the 'apply_cb' method.
So it's just a guess, but did you check the boolean 'added1'?
I think there can occur some type conversion problems, perhaps you can try the following:
Dim body1(0) As TaggedObject
body1 = selection0.GetSelectedObjects()
added1 = selecteObjectList1.Add(body1)
 instead of using
body1 = selection0
Hope that helps!
Bye,
Flo
Hi Flo,
Thanks a lot! That was the missing piece.
