Connection between derived features
Hello everyone!
Let's assume I have a point set. I projected it to create projected curve feature. Does NX keeps any information as of which point on initial point set corresponds to which point on a projection feature? Is it possible to access this information via API?
Likewise, if I create hole package from point set, or projected curve (actually points) feature, does NX keeps information about which point corresponds to which hole? Or is it only possible to do by compairing points to hole origins?
