Console window inside NX
Hello all,
I remember someone showed a new feature inside NX (not Teamcenter) to show a console window where we can see the output sent to STDOUT from custom code.
Does somebody remember how to enable it in NX11 or NX12?
I opened a GTAC ticket but they sent me instructions to do this in Teamcenter, which is a different story.
Thank you
8 REPLIES 8
Re: Console window inside NX
Note you can write to the "information" window.
You can also write to the NX log file (syslog)
Not exactly the console window, but (to me) reasonably close.
Listing window example (VB)
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
lw.WriteLine("Your Text here")
Syslog example (C/C++)
UF_print_syslog("Your text here", FALSE);
The listing window is visible as you run the program.
The syslog is "permanent" (e.g. if the NX session crashes)
Finally I found how to enable it.
set DISPLAY_CONSOLE=1
Now, it's time to explore its capabilities Smiley Happy
Thank you Ken, very helpful...
To write to the NX syslog in .NET, you use:
theSession.LogFile.Write("my custom message")
Hope this helps.
Production: NX12.0.2, VERICUT 8.2, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 11.4
Development: C (ITK), .NET, Tcl/Tk Testing: NX (1876) | AWC 3.4 Preparing: -
It's work for NX11 NX12 only? What about NX10?
This is not for NX10.
Can you please tell me where to find console window
In NX1202, in Measure dialog, there is option "Send Results to NX Console". When you measure something when this toggle ON after click OK or Apply, Console navigator will be added.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
