Constraining components
Innovator
Innovator
Is there a simple method that someone has created to make constraints at a distance between components?
Or any tips. When recording it just come back with a jumbled mess.
Re: Constraining components
below some code to constrain a component.
Should be a good start to create a distance constrain. Just record a distance constrain and edit the constrainType and Alignment accordingly. offcourse don't forget the distance value.
br
Fred
componentConstraint1.ConstraintAlignment = Positioning.Constraint.Alignment.CoAlign
componentConstraint1.ConstraintType = Positioning.Constraint.Type.Distance
   Sub AddConstrainToComponent(cmp1 As Component, dp1 As DatumPlane, dp2 As DatumPlane)
        Dim componentPositioner1 As Positioning.ComponentPositioner
        componentPositioner1 = s.Parts.Work.ComponentAssembly.Positioner
        componentPositioner1.ClearNetwork()
        componentPositioner1.BeginAssemblyConstraints()
        Dim allowInterpartPositioning1 As Boolean
        allowInterpartPositioning1 = s.Preferences.Assemblies.InterpartPositioning
        Dim network1 As Positioning.Network
        network1 = componentPositioner1.EstablishNetwork()
        Dim componentNetwork1 As Positioning.ComponentNetwork = CType(network1, Positioning.ComponentNetwork)
        componentNetwork1.MoveObjectsState = True
        Dim nullAssemblies_Component As Assemblies.Component = Nothing
        componentNetwork1.DisplayComponent = nullAssemblies_Component
        componentNetwork1.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing
        Dim markId2 As Session.UndoMarkId
        markId2 = s.SetUndoMark(Session.MarkVisibility.Invisible, "Assembly Constraints Update")
        Dim constraint1 As Positioning.Constraint
        constraint1 = componentPositioner1.CreateConstraint(True)
        Dim componentConstraint1 As Positioning.ComponentConstraint = CType(constraint1, Positioning.ComponentConstraint)
        componentConstraint1.ConstraintType = Positioning.Constraint.Type.Touch
        componentConstraint1.SetName("ALIGN_XY")
        Dim constraintReference1 As Positioning.ConstraintReference
        constraintReference1 = componentConstraint1.CreateConstraintReference(cmp1, dp1, False, False, False)
        Dim constraintReference2 As Positioning.ConstraintReference
        constraintReference2 = componentConstraint1.CreateConstraintReference(s.Parts.Work.ComponentAssembly, dp2, False, False, False)
        constraintReference2.SetFixHint(True)
        componentNetwork1.Solve()
        Dim nErrs1 As Integer
        nErrs1 = s.UpdateManager.AddToDeleteList(componentNetwork1)
        componentPositioner1.DeleteNonPersistentConstraints()
        Dim nErrs3 As Integer
        nErrs3 = s.UpdateManager.DoUpdate(markId2)
        Dim nullAssemblies_Arrangement As Assemblies.Arrangement = Nothing
        componentPositioner1.PrimaryArrangement = nullAssemblies_Arrangement
        componentPositioner1.EndAssemblyConstraints()
    End Sub
Frederik Verscheure
Evolve Consulting bvba
Freelance NX & Teamcenter consultant
frederik@evolve-consulting.be
