Conversion from Cylindrical dimension to vertical dimension
Hello All,
Is there any possibility to convert cylindrical dimension to vertical dimension?
To be more precise I want to change the same particularly in those cases where it's not possible to change by editing the dimension and when I try to change in measurement method option.
I have attached an image to show exactly what I want.
Please help me on this issue.
