Convert JT file to 2D image using JTOpen
Hi All,
I am working with JTOpen Toolkit with which i am trying to convert a JT file to any 2D formats(png,jpeg). Is there any API/exe which does that ??
Also does JTOpen tool kit provides a JAVA API/SDK tp process JT Files?
Thanks in Advance.
-Althaf
Re: Convert JT file to 2D image using JTOpen
Althaf,
Good morning.  The JT Open Toolkit is only available as a C++ API.
Steve
Thanks for the quick response. Does the C++ API provide the option to convert the CAD file into a 2D image(say PNG or JPG)? I did check the API docs, but was not able to find this information.
I don't see any calls for that.  It has calls for reading and writing JT, but I don't see any other formats.
Thanks again for the quick response. Do you know if the JT Open Toolkit has any other executable/API that converts CAD files into 2D images?
No, it does not.  It is intended to allow you to read and write .JT files.
You could try searching the web to see if anyone has created such a converter.
If the file is loaded in NX, you can use the NXOpen API to export screenshots (jpg, png, bmp, tiff, etc). Look for CreateImage in the NXOpen docs.
Thanks Steve.Will check for a possible solution
