Do you mean
Reply
Solved! Go to solution
Converting Depth of Cut units from %tool to partunits
Hi All,
I have the following scenario.
Operation: Rough Turn
Cut Depth: Constant
Maximum Distance : 0.001 in (OR) %Tool
The units for Maximum distance can be "in" or "%tool"
I have a program that gets me the value of Maximum distance and the units.
However, I would like to convert %tool to inches to do some calculations.
e.g.: 10 %Tool = ____in
I am not able to find any API that  converts %Tool into inches.
Kindly suggest if there is any method of doing it.
Faisal Ahmed
Solution
Solution
Accepted by topic author Faisal
‎02-09-2017 01:34 AM
Re: Converting Depth of Cut units from %tool to partunits
Multiply the %Tool value times the insert diameter of the tool.
Mark Rief
Retired Siemens
Thanks mark!
