Create Drawing View Example, VB.NET/SNAP
I am trying to search for some examples to create views using VB.NET/SNAP. I tried to google but I only found one example for solidEdge
If anyone has some examples, please help me out.
Re: Create Drawing View Example, VB.NET/SNAP
Below is an example of adding top view to current drawing on Solution Center.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=add+drawing+view&dt=n...
Suresh
Even I have not found any useful VB journal on Solution Center (GTAC) to create multiple views in the drawing.
I have recorded the journal using 'View Creation Wizard' command, but while running the journal I stuck with the following error.
Then I used 'Base View' command while recording the journal to create different multiple views, it is working without any problem.
Ganesh Kadole, QA Analyst (PLM), SQS
Testing: NX 11 | NX 12 | TCIN
TC 11.2 | TC Vis 11.3 | AWC 3.2
