Create Leader to Point in drawing
I want to make a journal to create leader at all points in the drawing.
I have created some points in a model and then made a drawing.
I am getting coordinates value as defined in part but I want the point location wrt to drawing.
how to get it?
Please find the attached file for code.
Re: Create Leader to Point in drawing
Esteemed Contributor
Have you tried the hole-table?
It creates a table of the coordinates of points, like center of holes, might be an option.
I am trying to create leader at the points in the drawing, not a table.
When I run the attached journal it is creating leader but the length of it is too long because it is taking a value of point wrt to model.
So my point is to how to create leader near to the point.
Please find the attached image for more information
There is a wrapper method to map a model point to a drawing point.
Public Sub MapModelToDrawing ( member_view As Tag , model_pt As Double(),  map_pt As Double())
Frank Swinkels
Hi Bhavik,
It's not happening because the points are Point3d which returns location of point3d.
You should manually have some location for the leader line/note.
like- point4= New point3d(200,200,0)
something like that.
regards,
Abhi
Yes. I got the solution.
I am doing it by expanding View and then inserting notes.
And adding notes by getting coordinates of points.
Thats cool.
please make this query as solution.
Abhi
