Create annotation with text attribute <>
When I create annotation with specified font style "barcode" it will label as <F26>. But this value will change when I use  another drawing file....how can I know this value before use?
Terry
Re: Create annotation with text attribute <>
There is a font table that is different for any part. You can search for a font like this:
For i = 1 To workPart.Fonts.GetLength()
Try
theSession.LogFile.WriteLine("Number: " & i & vbTab & "Name: " & workPart.Fonts.GetFontName(i))
If workPart.Fonts.GetFontName(i) = "ISOCPEUR" Then
isNotISOCPEUR = False
tmpFontIndex = i
theSession.LogFile.WriteLine("")
theSession.LogFile.WriteLine("ISOCPEUR found at index: " & i)
Exit For
End If
Catch
theSession.LogFile.WriteLine("Error found for Font Number: " & i)
End Try
Next I
If it cannot be found, you can add it by using this line "tmpFontIndex = workPart.Fonts.AddFont("ISOCPEUR", FontCollection.Type.Standard)"
Then you have the index number. If you change your template files and add the font it is always available...
