Create lightweight bodies with NX Open.
Builder
Builder
Hi
We would like to create with User functions, lightweight bodies, exactly as they are created online with Assemblies --> Advance --> Representations --> Create.
The lightweight bodies that are created with Product Outline are not as axact as in Representations.
Can we create Representations lightweight bodies?
Thanks a lot,
Idit Gvirtz
Re: Create lightweight bodies with NX Open.
Yes, you can do this.
The relevent functions mostly reside in the following classes:
  • NXOpen.UF.UFFacet
  • NXOpen.Facet.FacetedBodyCollection
In general, the NXOpen.UF.UFFacet functions were originally intended for use with NX-facet bodies, but, in many cases, they have been enhanced to work with JT-facet bodies, too. Conversely, the NXOpen.Facet functions work almost exclusively with JT-facet bodies.
The two specific functions that are likely to be useful are:
  • NXOpen.UF.UFFacet.FacetSolid
  • NXOpen.FacetedBodyCollection.CreateFacetBody
The first of these always creates an NX facet body, and the second one creates a JT facet body
山田
yamada
Builder
Builder
Hi Yamada
Thanks a lot for the quick and very good answer.
It helped me a lot.
Idit Gevirtz
