Creating Linked Bodies
Innovator
Innovator
Is there any easy way to programmatically create a linked body in a selected component?
Re: Creating Linked Bodies
That would depend on your definition of "easy"...
You can find some code samples in the GTAC solution database:
https://solutions.industrysoftware.automation.siemens.com/result.php?sort=desc&p=1&q=nxopen+sample+w...
Also, a code example here:
http://www.eng-tips.com/viewthread.cfm?qid=336450
And here:
http://nxjournaling.com/content/assembly-boolean-0
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
