Cursor selection and cursor motion callback from blockstyler?
Does block styler support cursor selection and motion callback?  It allows the user to use a cursor for selection and run the callback function while cursor is moving?
The similar function like "Geometric Properties" in dynamic analysis, user can use cursor to inspect any face from model.
I know the old UI styler can do this but not sure the block styler and how to make this setup.
Terry
