Customise Draft Templates - UGII_env_ug.dat variable
Hi
I would like to direct a number of users to common Template directory on our network ensuring all work to latest release.  Basically I want to update the UGII_env.dat file with new location of Template directory. Ive looked in the UGII_env_ug.dat file to find the appropriate variable but cannot identify the correct one!
Could anyone please let me know either the variable to use or alternative method.
Thanks any advice will be much appreciated
Dennis
Re: Customise Draft Templates - UGII_env_ug.dat variable
UGII_TEMPLATE_DIR should be the one pointing to customized PAX files for all your template files.
Thanks Stefan,
Ive looked and this isnt listed in the UGII_env_ug.dat
Could you send example please if possible
See these Solution Center entries.
Thanks,been a while since I edited variables and I had forgot to enclose location in speech marks!
