Customize routing design rule
I'm using NX 10 and i want to create my own design rule...
I have used the same exemple in NX Help but i'm missing somthing in the implementation.
I created a dll(linked lib) and added <rule> </rule> with description and dll name in the ugroute_elec_xxx.xml
when i see design rules, i found my rule  added but i think it's not functionnal when i run the check.
Do i have to place the dll file in a particular path or what.
Any Help?
