Cycle through Groups
Builder
Builder
I want to write a VB Program in Drafting application to cycle through all groups and do something on them but I don't know the exact hierarchy of groups in workpart:
Dim Group As Group
For each Group In '......'
'Do something
Next
Sina shojaee
Re: Cycle through Groups
Here's one way to cycle through groups in a part:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim tmpGrp As NXOpen.Tag = NXOpen.Tag.Null
        Dim myGroup As Group
        Dim numMembers As Integer
        Dim memberTags() As Tag
        Dim numOwningGroups As Integer
        Dim owningGroups() As Tag
        Do
            theUfSession.Obj.CycleObjsInPart(workPart.Tag, UFConstants.UF_group_type, tmpGrp)
            'skip the initial null tag
            If tmpGrp = NXOpen.Tag.Null Then
                Continue Do
            End If
            myGroup = Utilities.NXObjectManager.Get(tmpGrp)
            lw.WriteLine("group name: " & myGroup.Name)
            theUfSession.Group.AskGroupData(myGroup.Tag, memberTags, numMembers)
            lw.WriteLine("  group contains: " & numMembers.ToString & " members")
            theUfSession.Group.AskAllOwningGroups(myGroup.Tag, numOwningGroups, owningGroups)
            If numOwningGroups > 0 Then
                lw.WriteLine("  owned by: " & numOwningGroups.ToString & " other group(s)")
                'theUfSession.UF.Free(owningGroups)
            End If
            lw.WriteLine("")
        Loop Until tmpGrp = NXOpen.Tag.Null
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
