DFA syntax check in ICE
Hello everyone!
I'm really stuck at the following question - how to perform dfa file syntax check in ICE? I can open dfa file in ICE and press Syntax check, but all I invariably get is a message "syntax error" without any further information.
On the whole, what is the best practice for the dfa file development using ICE?
Re: DFA syntax check in ICE
You are doing it correctly, It has been my experience that ICE is a bit buggy. Try reload all in NX KF Navigator and checking the NX log file. You will likely find more information there.
Ric Hotchkiss
Applications Consultant
rhotchkiss@daasolutions.com
O: 860-749-3832x214
F: 860-749-3842
C: 860-463-8486
Design Automation Associates Inc
68 Bridge Street, Suffield CT 06078
Website: http://www.daassolutions.com
Engineering Software & Engineering Services:
Design Automation, Training & Mentoring
NX, Knowledge Fusion, NX/Open, Checkmate
Mechanical Design, Structural & Thermal Analysis
