cancel
DLX error in NX10
I'm trying to run a new dialog box written in python on NX10.
I changed my environment path variable to
variable name="%USERPROFILE%\myproject"
variable value= "C:\Program Files\Siemens\NX 10.0\UGII\"
The python file and the dxl file are in C:\Users\myusername\myproject\src\application
Re: DLX error in NX10
C:\Users\myusername\myproject\src should be referenced by UGII_USER_DIR, UGII_GROUP_DIR, UGII_SITE_DIR, or be an entry in a text file referenced by UGII_CUSTOM_DIRECTORY_FILE.
Hi Jim,
Thanks for the tip.
so variable name should be "UGII_USER_DIR"
and variable_value - "C:\Users\myusername\myproject\src"
correct?
Yes. UGII_USER_DIR=C:\Users\myusername\myproject\src should work.
