12-06-2014 11:57 AM
To all,
I have a macro which aim to extract the result 'BeamElementForce' for a given element in a Response Simulation (Event = transient). I am getting there but I am thinking about catching errors. At the moment I want to "catch" the fact that for the following user supplied data;
1. Response Simulation specified =Exists
2. Event specified = Exists
3. Element specified = Exists
there is no result 'BeamElementForce' available. In other words it's all good until the last step when the macro needs to extract the data.
I have pasted an extract of the code I have developed so far (might not be pretty but it works!)
Maybe there a way of using a "Catch...Try" where the code tries to create the response function as it might fail (as the output does nto exits)
[RSEvent1.EvaluateElementalFunctionResponse(elementalFunctionEvaluationSetting1) ]
Any suggestion welcome in helping to expand my (NX) vba knowledge
Thanks in advance
JXB
'---------------------------------------------------- Dim RespSimSolFound As CAE.ResponseSimulation.Solution For Each RSEvent1 As CAE.ResponseSimulation.RSEvent In RespSimSolFound.GetEvents() theSession.DataManager.LoadFile(pathAFUFile) elementalFunctionEvaluationSettingBuilder1.ResultType = CAE.ResponseSimulation.EvaluationResultType.BeamElementForce Select Case LoopID Case 1 elementalFunctionEvaluationSettingBuilder1.DataComponent = CAE.ResponseSimulation.DirectionDataComponent.Ax Case 2 elementalFunctionEvaluationSettingBuilder1.DataComponent = CAE.ResponseSimulation.DirectionDataComponent.Sy Case 3 elementalFunctionEvaluationSettingBuilder1.DataComponent = CAE.ResponseSimulation.DirectionDataComponent.Sz End Select elementalFunctionEvaluationSettingBuilder1.SetDestinationElements(destinationElements1) Dim nXObject1 As NXObject nXObject1 = elementalFunctionEvaluationSettingBuilder1.Commit() Dim elementalFunctionEvaluationSetting1 As CAE.ResponseSimulation.ElementalFunctionEvaluationSetting = CType(nXObject1, CAE.ResponseSimulation.ElementalFunctionEvaluationSetting) RSEvent1.EvaluateElementalFunctionResponse(elementalFunctionEvaluationSetting1)
Next RSEvent1
12-16-2014 08:47 AM
just managed to come back to my problem (got distracted by real work!)
Looks like a simple 'Try..Catch' loop does the job
ElmFnEvalSettingBuilder1.SetDestinationElements(destinationElements1) Dim nXObject1 As NXObject nXObject1 = ElmFnEvalSettingBuilder1.Commit() Dim ElmlFnEvalSetting1 As CAE.ResponseSimulation.ElementalFunctionEvaluationSetting = CType(nXObject1, CAE.ResponseSimulation.ElementalFunctionEvaluationSetting) Try RSEventToProcess.EvaluateElementalFunctionResponse(ElmlFnEvalSetting1) Catch ex As Exception theLW.WriteLine("--No results exist for the Element ID specified.") 'Dim Msg as String = "--No results exist for element ID: " & theFEElm.Label 'Dim Title as String = "The Title here" 'MsgBox(Msg, vbOKOnly + vbCritical, Title) 'theNXMessageBox.Show(Title, NXMessageBox.DialogType.Error, ex.ToString) Return FinalDataEmpty End Try
JXB
