Default Failure Update Action prior to NX 9
Hi All,
I am working in .vb NXOpen for NX 8.5 and would like to set the default failure update action to be Accept All. However, as far as I can tell, you can only do this in NX 9. I have found a way to accept all failures for a specific object but the object that fails changes every time and could potentially belong to different parts. Is there a work-around so that I can set the failure update action to be Accept All without knowing which object will fail or without using NXOpen.Update.SetDefaultFailureUpdateAction?
Thanks!
Re: Default Failure Update Action prior to NX 9
There is a wrapper method for a UF_MODL function that might work for you - UFModl.SetUpdateFailOption.
One of the options you can pass is UpdateAcceptAll.
