Defining text origin of dimensions
Hello All,
I was trying to add a dimension in my specified location.
i am able to set the dimension origin like this-
Dim Origin1 as Point3d
Origin1 = New Point3d(60, 280, 0.0)
horizontalDimension1.AnnotationOrigin = Origin1
Now I want to set dimension text location as well.
But I didn't find any API for that.
Please help me to set text origin of a dimension.
Re: Defining text origin of dimensions
I think, if you set the property 'IsOriginCentered' to false, the dimension text origin will be the Origin1 you specified.
Suresh
Hi @Technisites
Yes, You are right. Now I achived the location of the dimension text.
Thanks for your support.
Abhi
