Delete Curve By Name In NX 11
Builder
Builder
I am trying to delete curve by searching its name.
I have used below code and it is working in NX 9 and NX 10 but it is not working in NX 11.
Can anyone please help me to find my mistake ?
Sub Main
theSession = Session.GetSession()
workPart = theSession.Parts.Work
displayPart = theSession.Parts.Display
Dim Curves As CurveCollection = workPart.Curves
Dim bodyname As String = Line
For Each oCurve As Curve In Curves
If oCurve.Name = bodyname Then
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Delete")
Dim notifyOnDelete1 As Boolean
notifyOnDelete1 = theSession.Preferences.Modeling.NotifyOnDelete
theSession.UpdateManager.ClearErrorList()
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.AddToDeleteList(oCurve)
Dim nErrs2 As Integer
nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
theSession.DeleteUndoMark(markId1, Nothing)
End If
Next
End Sub
Re: Delete Curve By Name In NX 11
Did you get any error while running this code in NX 11.
Based on my observation, below two possibilites are there for not working.
1. Compare the string in lower case or upper case.
If oCurve.Name.ToUpper = bodyname.ToUpper Then
2. Markid2 is passed for update, but no where mention in the code. Markid1 is created before adding the curve into the delete list. So pass the Markid1 for update.
'nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
nErrs2 = theSession.UpdateManager.DoUpdate(markId1)
Selvaraj C
CAD Automation Engineer
NX 9 | NX 11 | Teamcenter 10
Selvaraj C
Builder
Builder
Thanks for the correcting me.
It is working now.
