Delete empty attribute
I've this code that delete empty attribute.
using System;
using NXOpen;
public class NXJournal
  public static void Main(string[] args)
    Session theSession = Session.GetSession();
    Part workPart = theSession.Parts.Work;
    NXObject[] objects1 = new NXObject[1];
    objects1[0] = workPart;
    AttributePropertiesBuilder attributePropertiesBuilder1;
    attributePropertiesBuilder1 = workPart.PropertiesManager.CreateAttributePropertiesBuilder(objects1);
    attributePropertiesBuilder1.IsArray = false;
    attributePropertiesBuilder1.StringValue = "";
    attributePropertiesBuilder1.Category = "";
    attributePropertiesBuilder1.Title = "";
    attributePropertiesBuilder1.Delete(workPart);
    NXObject nXObject1;
    nXObject1 = attributePropertiesBuilder1.Commit();
    attributePropertiesBuilder1.Destroy();
  public static int GetUnloadOption(string dummy) { return (int)Session.LibraryUnloadOption.Immediately; }
 This works fine, but if the part hasn't an empty attribute give an error.
Can someone correct the code ?
Thank you...
Using NX 11 / RuleDesigner PDM
Re: Delete empty attribute
replace attributePropertiesBuilder1.Delete(workPart); with
if (attributePropertiesBuilder1.ArrayIndex>0)
Doesn't work.
Thank you...
Esteemed Contributor
The problem is the trailing semi-colon ( ; ), since the condition isn't used for the delete method.
You need to make sure to really use the code as posted or on one and the same line.
First way of doing it:
Second way of doing it:
if (attributePropertiesBuilder1.ArrayIndex>0) attributePropertiesBuilder1.Delete(workPart);
Thank you Stefan,
it's works fine.
Thank you...
cubalibre00 you made a mistake while pasting my code.
