Deleting Notes from View
Builder
Builder
I have created one drafting view with few notes containing some text value.
I am trying to delete that View through journal and it is working good sometime and sometime not.
I have used below code.
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Delete")
Dim notifyOnDelete1 As Boolean
notifyOnDelete1 = theSession.Preferences.Modeling.NotifyOnDelete
theSession.UpdateManager.ClearErrorList()
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete")
Dim objects1(0) As NXObject
Dim drawingView1 As Drawings.DrawingView = CType(workPart.DraftingViews.FindObject("Example"), Drawings.DrawingView)
objects1(0) = drawingView1
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.AddToDeleteList(objects1)
Dim notifyOnDelete2 As Boolean
notifyOnDelete2 = theSession.Preferences.Modeling.NotifyOnDelete
Dim nErrs2 As Integer
nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
theSession.DeleteUndoMark(markId1, Nothing)
End Sub
End Module
