Detecting a closed set of curves
Innovator
Innovator
Given a set of curves.
How would you determine if they form a closed polyline?
Re: Detecting a closed set of curves
Try to create join curve using the given set of curves and pass the join curve tag into this API 'UF_MODL_ask_curve_closed' which returns whether a curve is a closed curve or not.
If you not able to create join curve feature, then it's resulted as open curve type.
