Distance constraint problem
Hello all,
I am trying to give distance constraint to components using componentConstraint2.SetExpression(value.ToString());
for example
componentConstraint2.SetExpression(" 100 ");
componentConstraint2.SetExpression("  -100 ");
for both positive and negative values component is moving towards negative direction.
please refer the attached images.
3 REPLIES 3
Re: Distance constraint problem
have you tried setting a "fix" constraint to one of the objects prior to your code execution?
MGeyer
Yes base component is fixed.
Set right hand side for the expression as your value
componentConstraint1.SetExpression("0");
Expression expression1;
expression1 = componentConstraint1.Expression;
componentNetwork1.AddConstraint(componentConstraint1);
expression1.RightHandSide = distance;
componentNetwork1.Solve();
