Divide curve over point on itself C++
I have a curve which has a point on it that I know the coordinates of, how would I write a function to divide it using this point as a bounding object?
More importantly, once it is divided, how can I apply the properties of the original line to the new line made by the division? When a curve is divided a curve with the original name and properties and an arbitrary "line1" will remain.
(C++)
Any help would be greatly appreciated
Re: Divide curve over point on itself C++
There is a sample code in the solution center.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=divide+curve&dt=nx-ap...
It basically involves creating a copy of the original curve and trimming both curves to the point from either ends.
Suresh
