DividingObjectsSection API replacement
I'm trying to port a C++ User Function from NX8 to NX10.
The old version is using the following APIs:
NXOpen::Features::DividefaceBuilder::DividingObjectsSection();
NXOpen::Features::DividefaceBuilder::SetDividingObjectsSection();
These functions are no longer available under NX10. As suggested by the manual, the new API DividingObjectsList should be used, but I cannot find any meaningful solution how to use it. Could you please help me, how to replace these functions with the new code?
Thanks!
