Does nxtocgmdirect requires separate license
Hello Experts,
I have configured nxtopv direct on Teamcenter 9126. Nx is 8.0.3. It works fine and generates JT.
Now I have configured nxtocgmdirect, license server is defined in nxtocgmdirect.sh as well which is same in nxtopvdirect.sh
When I try to submit a translation request, it terminates with below error
Initialize failed with code 949982
This error means
NX License Error: License server system does not support this feature. [ -18 ]
Does nxtocgmdirect requires a separate license.
Re: Does nxtocgmdirect requires separate license
What heppens when you (interactively) do a File -> Export -> CGM?
Q: What heppens when you (interactively) do a File -> Export -> CGM?
A : When I interactively do File -> Export -> CGM or File -> Export -> PDF, the corresponding CGM and PDF gets generated and attached to the design revision.
Check the syslog of the translation if this is really a license error.
It should also contain the name of the requested license.
In addition you can check the licensing log at the license server for the rejected license.
It sounds like you are using Teamcenter?
If so what version?  There could be other ways to do this.
