Double field side-by-side in Block Styler
Hello everyone!
Is it possible in Block Styler to put two double boxes side-by-side, the same as it is used in some OTB NX menus?
Re: Double field side-by-side in Block Styler
Stefan_Pendl 3rd Gear
3rd Gear
There are multiple ways to do this:
  1. specify multiple columns in the group definition
  2. use a double table
  3. use the attachment options of the elementsGroup ColumnGroup Column
    Enumeration ColumnEnumeration Column
    Left Object AttachmentLeft Object Attachment
    Right Object attachmentRight Object attachment
    Number TableNumber Table
Hope this helps.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
Yes, use the attachments to set the Left and Top attachment of the second Double Value:
If you want it to look even more like your OOTB examples, set the Label for each Double Value to and empty string.
With attachments you can create almost any layout in your dialogs.
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX11.0.2.7 MP5] & [NX12.0.0.27 MP1]
I understand 1 and 3, but what is "an array of double input boxes"? Could you please explain?
3rd Gear
Edited the post to read "double table" which is the correct spelling.
Included some images for reference too.
Thank you! I will study it. Man Happy
