DrawingSheetBuilder.EngishSheetTemplateLocation
Currently pulling from the master TeamCenter database using the guid.  This is provide via the journal when doing File->Add new sheet. Example:
drwSheetBldr.EnglishSheetTemplateLocation =
"%UGMGR=V3.2 PH=<phcode> PN=L3_BDR_TUBE_AV PRN=- RT=\"has shape\" AT=\"UG master part file\" ";
I was shown the pax file that is pushed to Design engineer and attempted to use instead. This failed. does anyone know addtional methods for template locations?
